Sound in Dosbox
First post, by Robc
Hi I have tried using Dosbox to run Arena and Ultima however while I can get both games to run whatever I do I am unable to get any sound. I would appreciate any help as it is quite annoying as it takes away from the immersion of the game.
Thank you in advance
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Details, we need details. Version of DOSBox? Default configuration? Using a frontend? Installed how? Configured sound how?
_________________
Reply 2 of 3, by Robc
Oops sorry forgot the details, it is dosbox 0.73 on starting dosbox it says set blaster=A220 I7 D1 H5 T6 sorry im not sure what you mean by frontend. The game is installed onto the C drive and i ran install in the command prompt to configure the sound and picked the option that gave A220 I7 and D1
Sorry i cant explain it very well it has been years since i used Dos and i was alot younger.
Reply 3 of 3, by MiniMax
Rank Moderator
Moderator
http://tinyurl.com/2wwte3
_________________
