First post, by DoSi
Hi,
Is there a way to change the CPU cycles from within dosbox?
At least for me, this would be useful.
I would like to create .bat files to run games..
For example:
Arkanoid.bat
z:\CPUCYCLE.COM 250 # Set the CPU cycles to 250
ark.com
z:\CPUCYCLE.COM 3000 # Return to default
Or something like that...
Or.. is there a way to update it programatically from within DosBox using a int command or something of the sort?
Thanks,
Reply 1 of 5, by Freddo
cycles 250
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
config -set "cpu cycles=fixed 250"
Water flows down the stream
Reply 3 of 5, by DoSi
Thanks. Exactly.
Reply 4 of 5, by SKARDAVNELNATE
From the readme:
To set the cpu cycles to 10000:
config -set "cpu cycles=10000"
What does adding fixed do?
Reply 5 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Nothing, but it's the official way.
1+1=10
