First post, by rotk6
I was very excited to play Moo2 since I haven't played it in years and it'd still my favorite game. I downloaded the latest version of DOSBOX and my problem is that I have a Dual 1.8 ghz g5 PowerPC and the game runs SLOW enough that it's irksome and hard to play with delayed clicking and lagging mouse. I have the frame skip at 1 and the CPU speed at 3000 and it's still so slow... Even after I turned the sound settings to 'No MIDI' and 'NO Digital sound'...
I don't understand enough about computers really to fix this by myself so I was wondering if anyone here had the same problems or would know how to step by step talk me through getting this game running like normal and smooth.
Thank you in advance.
Reply 1 of 33, by MiniMax
Rank Moderator
Moderator
3000 or 30000 ?
_________________
Reply 2 of 33, by rotk6
typo... hehe...
I was running it at 30000.
Now I'm running it on max with no frame skip and I still have problems. Sometimes I run it with frameskip 3 or 1 on cpu cycle max and it's still laggy. Is the problem my processor? The g5 is non intel which is the only thing I can think of that is slowing me down.
I have the same problems with Boxer, although I lag slightly less using dosbox.
Reply 4 of 33, by MiniMax
Rank Moderator
Moderator
rotk6 wrote:
Also I'm unsure how to change my frameskip and cpu cycles in-game.
INTRO SPECIAL
_________________
Reply 5 of 33, by MiniMax
Rank Moderator
Moderator
Try different output methods.
_________________
Reply 6 of 33, by rotk6
I'm sorry for my ignorance, but I don't really know what output methods means. Do you think you can explain it to me in the most base terms and let me know how I would go about changing my output methodology?
Reply 8 of 33, by MiniMax
Rank Moderator
Moderator
Editing the DOSBox 0.73 Preferences file is explained the last part of this post:
Re: 60 seconds guide to getting your game to run in DOSBox
Output methods and such are somewhere near the top, with a very short explanation / list of the possible values. For more info, there is the DOSBox wiki.
_________________
Reply 9 of 33, by rotk6
OK... so if i understand this right...
This is the file he wants me to mess with?
o 2.1 [sdl]
o 2.2 [dosbox]
o 2.3 [render]
o 2.5 [mixer]
o 2.6 [midi]
o 2.7 [sblaster]
o 2.8 [gus]
o 2.9 [speaker]
o 2.10 [joystick]
o 2.11 [serial]
o 2.12 [dos]
o 2.13 [ipx]
o 2.14 [autoexec]
Am I supposed to be working with the frameskip, aspect, scaler, core, cpu, cycles? Is there a difference messing with it at the dos prompt as opposed to doing it ingame?
Do you have any suggestions?
P.s. Thanks for the help.
Reply 10 of 33, by rotk6
Minimax that is pretty complex but I don't see anything that mentions output unless you are talking about that autoexec file at the bottom.
I really don't understand much about dos language so this is all a little confusing.
I think I'm in over my head.
I don't have the cd of this game.
Reply 11 of 33, by HunterZ
Some settings won't take effect during run-time (i.e., at the DOS prompt).
The start of dosbox.conf looks like this:
# This is the configurationfile for DOSBox .
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen.
# fulldouble: Use double buffering in fullscreen.
# fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
# autolock: Mouse will automatically lock, if you click on the screen.
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized. (pause is only valid for the second entry)
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=true
fulldouble=true
fullresolution=1024x600
windowresolution=original
output=ddraw
Reply 12 of 33, by MiniMax
Rank Moderator
Moderator
rotk6 wrote:
OK... so if i understand this right... This is the file he wants me to mess with? o 2.1 [sdl] o 2.2 [dosbox] […]
o 2.1 [sdl]
o 2.2 [dosbox]
o 2.3 [render]
o 2.5 [mixer]
o 2.6 [midi]
o 2.7 [sblaster]
o 2.8 [gus]
o 2.9 [speaker]
o 2.10 [joystick]
o 2.11 [serial]
o 2.12 [dos]
o 2.13 [ipx]
o 2.14 [autoexec]
That looks like something from the Wiki. You don't want to edit that 😀 You want to edit the DOSBox 0.73 Preferences file on your own Mac using TextEdit.
Difference? Not really. Except that what you do at the prompt is gone the next time you start DOSBox. Things in the Pref-file is permanent (well, until you edit them again).
_________________
Reply 13 of 33, by rotk6
Ok... I'm just interested in getting this thing running so that when I click the turn button it doesn't take 6 seconds to get to the next turn. 😁
I think I will tackle the autoexec stuff after.
I have tried output=ddraw, surface, overlay.
Now trying: output=opengl
Only one more to go... openglnb. They have all seemed roughly the same so far. What is the default output?
Offhand... Have other people had a hard time with g5 powerpc dual 1.8's?
Reply 14 of 33, by rotk6
Still no luck... Been at this for two days trying everything.
I am coming to the conclusion that my g5 is simply too slow to run the dos emulation which is strange to understand. The g5 is so much more powerful but somehow has problems running a 260 mb game and freakin' DOS...
Please let me know if anyone else is having similar issues with their computer and dosbox. Anyone running dosbox on a non-intel mac osx and having similar slowdown issues? Any help from anyone would be greatly appreciated.
Reply 15 of 33, by DosFreak
Since your using PowerPC you can not use dynamic recompilation which signifigantly speeds things up.
To add to the slowness you are playing a protected mode game which back in the day required a fairly powerful PC which means running it in DOSBox emulation requires a powerful PC.
So:
You need an x86 processor so you can use dynamic recompilation.
Make your games work offline
