First post, by Hater Depot
I didn't find it in the compatibility database, but I have the DOS port of Revolution X working in 0.73 on Windows 2000. Gameplay and menus run fine but load times are very long and cause the music to stutter. I'm going to see if I can improve on that.
Reply 1 of 2, by Sinner
Increase CPU cycles either in the dosbox.conf file or with Ctrl+F11/F12 inside dosbox. Additionally, you can set the scaler to normal and use frameskip to increase speed though I doubt that will help much here.
[cpu]
core=normal
cycles=10000 (Or more)
