First post, by Flack
it seems, when i try to instal heroes of might and magic, he says that there are no devices on my pc, an empty list. i also got that same problem with Daggerfall, but in daggerfall, he says that i don't got enough space left on my C:\ , and i can't change the install path 😖 an it's mounted 😖
(BTW i am using my game harddisk D:\ , thats its where all my DOS games at)
Thanks in advance
Reply 1 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Write your mountings
1+1=10
Reply 2 of 7, by Flack
how do i do that?> im pretty new to DOSbox
Reply 3 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
...what do you type into dosbox?
1+1=10
Reply 4 of 7, by MiniMax
Rank Moderator
Moderator
For Heroes of Might and Magic:
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
For Daggerfall: http://static.bethsoft.com/downloads/games/da … nstallation.pdf
_________________
Reply 5 of 7, by Flack
Ok i followed the Daggefall instalation guide, and i got this:
i've mounted a cdrom drive and all, did exactly everything what it told me to do.
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
Daggerfall instead of daggerfall.
Please follow the instructions
Water flows down the stream
Reply 7 of 7, by Flack
lols thanks 😜
i r good in failing
