First post, by johnyjj2
Hello!
I downloaded and installed DOSBox & Turbo Pascal 7.0 on it. I tried to compile my program on TP7.0 but there is weird problem. I open trc.pas, press F9 (Make) and see "Error 15: File not found (CDF.TPU)" in the window "\PROG\TRC.PAS". I check and there exists file CDF.TPU in the directory C:\dosprog\prog where on DOSBox I emulate disc C by command "mount c c:\dosprog\". What should I do to compile this program? It is program written many years ago in TP and I need to run it on Windows XP.
Greetings!
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
you probably have the library path wrong in turbo pascal
Water flows down the stream
Reply 2 of 2, by johnyjj2
Thanks for your reply!
Do you know where I can change it? Compiler shows error and indicates that line in which there is only word cdf written, without any path or three-letters extension but with some keyword before it. In the project there are many different files, including $$, LIB, PAS, bak, BGI, CHR, LIM, MS, o, ppu, SCD, TPU, TRC, vhd but they all are in one directory.
Greetings!
