First post, by pig_10
I got a Roland CM-300 recently, and when I try to record something...
I found that it only has 32000hz sampling rate! to my knowledge, CM-500 is just a SC-55 without panel and buttons and output quality should be same. And Wikipedia says SC-55 has a 44100hz sampling rate.
Maybe I'm wrong? Maybe they're not same? However I'm planning to buy a SC-55mkII now...
