GUS mixControl default
First post, by peterferrie
I noticed that the Fallen Angel demo from A-Men won't run in DOSBox unless either the real Ultrainit.exe exists, or any DemoVT-based demo was run first. After much tracing, I see that if I write a 0x0c to the GUS base port, then Angel runs without any depenencies. That suggests something IRQ related. At a guess, I suppose that Angel is assuming that IRQs are always enabled. Would the world break if that was the default mixControl value?
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
Could you please check if ultrainit.exe does such a write as well (not followed
by a write to gusport+0x0b)?
It might even be enough to use myGUS.ChangeIRQDMA = true; for the gus
initialization code.
Reply 2 of 9, by lightmaster
demo might bue buggy, coz it was done in a hurry hehe..
Reply 3 of 9, by wd
Rank DOSBox Author
DOSBox Author
😀 Though demos' gus support is quite good.
Reply 4 of 9, by lightmaster
Yeah that's right!
Reply 5 of 9, by peterferrie
>Could you please check if ultrainit.exe does such a write as well (not followed by a write to gusport+0x0b)?
Ultrinit.exe (I got the name wrong before) writes 0x0b to gusport, then writes 0 to gusport+0x0b, plus lots of other combinations, too.
>It might even be enough to use myGUS.ChangeIRQDMA = true; for the gus initialization code
I think that it's not a DMA problem, but that the IRQ never fires.
Changing the mixControl value alone (not touching ChangeIRQDMA at all) makes the demo work. Changing ChangeIRQDMA without touching mixControl still hangs.
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
Could make sense, i'd expect a default of 8 (initializing mixControl that way) to work in this case.
Reply 7 of 9, by peterferrie
And it does work using a value of 8.
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Ok thanks.
What's the last value written to that port by ultrinit.exe?
Reply 9 of 9, by peterferrie
Last value is 0x0b.
