First post, by puzdir
I apologize for my English!
There is a Dos program for work that requires more than 615 kilobytes of memory lower dos + program loads into memory at the same time, more than 130 files.
Question: Does Dosbox simultaneous loading of more than 130 files, ie analog command "files = 140" in the file config.nt
Reply 1 of 5, by Kippesoep
DOSBox is intentionally limited to 127 files. There is no way to raise this except by recompiling DOSBox. This is because very few programs (especially games) actually require that many open files and when they throw such an error message, it's commonly related to something else.
I have made a patched version which allows the files setting to be changed through the config file.
My site: Ramblings on mostly tech stuff.
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
does the application work/hang/crash ?
Water flows down the stream
Reply 3 of 5, by robertmo
you didn't actually said whether your patch allows what he wants or not 😀
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well the files=140 requirement is usually a requirement people think they need because the application hangs,
while in reality something else might be going on. At least I've been able after debugging various of such cases
So if it hangs, there is the possibility something else is going on
Reply 5 of 5, by Kippesoep
True, although I didn't say that it didn't either 😜 So I guess I didn't say anything at all 😁 Anyhow, DOSBox has a static setting of 127, my patch makes it dynamic and accepts any numeric value (although any value lower than 10 is silly, below 1 is stupid and any value above 255 will cause problems and your computer will explode with strawberry jam oozing from the power supply -- or perhaps not).
