First post, by SlimG
My Goal:
  • Launch a game from any platform with default dosbox
    settings, and without having to edit files when moving
    the game between platforms and paths.
  • Launch a game using only one path as argument to dosbox
Example game:
/dir/cg/dosbox.conf
/dir/cg/coolgame.exe
  1. dosbox -conf /dir/cg/dosbox.conf /dir/cg/coolgame.exe
    The problem: This would launch the game, but requires two path arguments, and thus is of no use.
  2. Adding the following to /dir/cg/dosbox.conf:
    [autoexec] MOUNT C . C: coolgame.exe […]
    [autoexec]
    MOUNT C .
    C:
    coolgame.exe
    before running
    The problem: This would only work if I run dosbox from within /dir/cg/
What I would wish for, is a variable named %CONFDIR% that would return the real directory of the current config file, so this would be the working sollution:
[autoexec] MOUNT C %CONFDIR% C: coolgame.exe […]
[autoexec]
MOUNT C %CONFDIR%
C:
coolgame.exe
before running […]
before running
Another way of solving this would be to change the default behaviour of dosbox to allways check for dosbox.conf before executing.
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
In other words, you want a command like this:
MyMagicDosbox /dir/cg/
that will execute the command
Now.... How hard can it be to write a program/script called MyMagicDosbox that will change the working directory to /dir/cg and execute the above mentioned command?
_________________
