First post, by sjs55
I got Daggerfall II for my friend, it didn't come with a manual, I loaded dosbox .73 on my desktop with windows vista 64bit, I did a imgmount but I still have a Z prompt, so when I put in the config command it doesn't accept it, I assume I am suppose to have a D prompt instead of the Z prompt after doing the imgmount? I also tried doing this on my laptop with XP, got the same result, plus it doesn't have that much disk space and I doubt it would run that well on that cpu. I do know a little about dos, use to have to write my programs in dos and assembler back in the early 70s, been quite awhile since I used it though.
