First post, by retro games 100
I spotted this AWE32 CT2760 on ebay, and bid on it because the unusual addition just made me curious. Bidding started and ended at 1 Euro. When I get it, do you think I should add a fan to that heatsink? 😉
Reply 1 of 59, by Old Thrashbarg
That's... different.
How about swapping out that little puny heatsink and watercool that sucker? I mean, just to be sure it's running cool. 🤣
Reply 2 of 59, by swaaye
omg somebody attached a greenie!!! 😳
Reply 4 of 59, by Malik
Is there a layer of hi-tech thermal paste beneath that heatsink?
Reply 5 of 59, by retro games 100
I'll let you know when it arrives. 😀
Reply 6 of 59, by ChrisR3tro
Great find! Maybe you can overclock that sucker to 88.2 khz :-)
for more Retro-related tidbits follow me on X under @ChrisR3tro.
Reply 7 of 59, by leileilol
Heatsinks can be necessary for those things. Have you ever heard an overheated AWE64? 😳
long live PCem
Reply 8 of 59, by Malik
Hmmm...seems like everyone gave excellent ideas here... connect that baby to a water cooler, add a 120mm extra-fast fan to really make sure it stays cool while "overclocking" it!
Reply 9 of 59, by retro games 100
It's just arrived, and I've installed it in a Win95 box. It works, but it's such a pity about the infamous hanging note problem - I tested Doom with a Roland SCB-7 daughterboard, and within a minute or so I could hear a stuck note. Regarding the heatsink, I pressed my fingers against it while it was playing Doom, and I could barely feel any heat on the heatsink, but perhaps I need to leave it on for much longer before it heats up?
The top SIMM holder is broken, but I've managed to push on a SIMM anyway. Seems to stick OK. The Win95 hardware auto detect feature locked up first time, but worked second time. The resources allocated were "all over the place", so I manually set them to the typical 5,1,5,330,620 settings.
Reply 10 of 59, by swaaye
i'd just take that ridiculous heatsink off 🤣. unless it's superglued or something of equal stupidity heh heh
Reply 11 of 59, by retro games 100
I kinda like it! It's, um, unique! 😀 It just touches the wavetable daughterboard, so it's dual purpose really - a special heatsink and nifty DB stopper. 🤣
Reply 12 of 59, by rfnagel
Man, that heatsink sure looks funny... definately not one on (all of) my CT2760's <G> -> http://www.cmoo.com/snor/weeds/Weeds_486DX4-100.htm . Never had a heat problem with any of mine... I don't remember them even getting luke warm.
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 13 of 59, by 5u3
EMU8K chips can get pretty hot, especially if you have plenty of RAM installed. Looks like the previous owner glued an old northbridge heatsink on top of it.
Regarding the "DB stopper" feature: Make sure the heatsink doesn't short something on the DB!
Reply 14 of 59, by prophase_j
If you decide you want to remove it a quick stay in the freezer will make the glue brittle and it should pop right off (assuming they didn't use epoxy or some other form of overkill).
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 15 of 59, by gerwin
Yesterday I installed my DB50XG again, and noticed one of the chips was really getting very hot in little time. Now guess what I did... 😉
Reply 16 of 59, by Amigaz
You put the motherload of waterblock on it to cool it? 😳 😁
Reply 17 of 59, by gerwin
Almost; I wil try to run the system submerged in the bath tub 😉
But for the time being, I happened to find the cutest little heatsink 😀
Reply 18 of 59, by rfnagel
Maybe my memory is fading, but I swear I never noticed any major heat from the EMU8K on any of my AWE32 cards. Like I said t'ho, prolly simply my memory fading.
Anyhow, I've had them for years (all with two 16 meg SIMMs installed), and they still work today... so I figger that the heatsink is prolly overkill.
Then again maybe not (this coming from someone who is totally paranoid about heat... check out that fan card in that old 486 in the pics in my previous link 🤣! 😀 )
Rich ¥Weeds¥ Nagel
Reply 19 of 59, by swaaye
🤣 also consider how old these cards are now and that they still work today. They would have heatsinks if they needed them.
