First post, by Stercus
I am trying to build DOSBox on a Gentoo Linux box. I am using the 0.73 build from portage which is obviously current based on the release info on the SourceForge site. I intend to use DOS box for to run an old DOS based BBS software package, so I don't need any sound support. I can go through and gut the adlib support from the source as a last resort. However, I would like to know if this build issue has been seen before and if there are any simple adjustments to the opl.cpp file to address this.
n file included from adlib.cpp:59:
opl.cpp:921: error: syntax error before `__attribute__'
opl.cpp: In function `void adlib_getsample(Bit16s*, int)':
opl.cpp:954: error: `op_type' undeclared (first use this function)
opl.cpp:954: error: (Each undeclared identifier is reported only once for each
function it appears in.)
opl.cpp:954: error: `cptr' undeclared (first use this function)
opl.cpp:979: error: `adlibreg' undeclared (first use this function)
opl.cpp:982: error: `vibtab_pos' undeclared (first use this function)
opl.cpp:982: error: `vibtab_add' undeclared (first use this function)
opl.cpp:984: error: `vib_table' undeclared (first use this function)
opl.cpp:987: error: `tremtab_pos' undeclared (first use this function)
opl.cpp:987: error: `tremtab_add' undeclared (first use this function)
opl.cpp:989: error: `trem_table' undeclared (first use this function)
opl.cpp:995: error: `op' undeclared (first use this function)
opl.cpp:1000: error: `vibval1' undeclared (first use this function)
opl.cpp:1000: error: `vibval_var1' undeclared (first use this function)
opl.cpp:1003: error: `vibval_const' undeclared (first use this function)
opl.cpp:1004: error: `tremval1' undeclared (first use this function)
opl.cpp:1005: error: `tremval_const' undeclared (first use this function)
opl.cpp:1009: error: `operator_advance' undeclared (first use this function)
opl.cpp:1010: error: `opfuncs' undeclared (first use this function)
opl.cpp:1011: error: `operator_output' undeclared (first use this function)
opl.cpp:1026: error: `vibval2' undeclared (first use this function)
opl.cpp:1026: error: `vibval_var2' undeclared (first use this function)
opl.cpp:1032: error: `tremval2' undeclared (first use this function)
opl.cpp:1055: error: `vibval3' undeclared (first use this function)
opl.cpp:1060: error: `tremval3' undeclared (first use this function)
opl.cpp:1095: error: `vibval4' undeclared (first use this function)
opl.cpp:1100: error: `tremval4' undeclared (first use this function)
opl.cpp:1105: error: `operator_advance_drums' undeclared (first use this
function)
opl.cpp:1457: error: `clipit16' undeclared (first use this function)
adlib.cpp: In member function `virtual void Handler::WriteReg(unsigned int,
unsigned char)':
adlib.cpp:63: error: `adlib_write' undeclared (first use this function)
…Show last 69 lines
function)
unsigned char)':
adlib.cpp: In member function `virtual void Handler::Init(unsigned int)':
adlib.cpp:79: error: `adlib_init' undeclared (first use this function)
adlib.cpp: At global scope:
adlib.cpp:84: error: syntax error before `}' token
In file included from adlib.cpp:88:
opl.cpp:952: error: redefinition of `void adlib_getsample(Bit16s*, int)'
opl.cpp:952: error: `void adlib_getsample(Bit16s*, int)' previously defined
here
here
function)
opl.cpp:1444: error: `clipit16' undeclared (first use this function)
adlib.cpp:90: error: redefinition of `struct Handler'
adlib.cpp:61: error: previous definition of `struct Handler'
adlib.cpp:113: error: syntax error before `}' token
In file included from adlib.cpp:155:
ymf262.c:266: error: semicolon missing after struct declaration
ymf262.c:266: error: abstract declarator `old_OPL3::<anonymous struct>' used as
declaration
ymf262.c:266: error: namespace-scope anonymous aggregates must be static
adlib.cpp: In constructor `Adlib::Module::Module(Section*)':
adlib.cpp:749: error: syntax error before `)' token
adlib.cpp:751: error: syntax error before `)' token
make[4]: *** [adlib.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: Leaving directory `/var/tmp/portage/games-emulation/dosbox-0.73/work/dosbox-0.73/src/hardware'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/var/tmp/portage/games-emulation/dosbox-0.73/work/dosbox-0.73/src/hardware'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/tmp/portage/games-emulation/dosbox-0.73/work/dosbox-0.73/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/games-emulation/dosbox-0.73/work/dosbox-0.73'
make: *** [all] Error 2
* ERROR: games-emulation/dosbox-0.73 failed.
* Call stack:
* ebuild.sh, line 49: Called src_compile
* environment, line 2520: Called games_src_compile
* environment, line 1421: Called die
* The specific snippet of code:
* emake || die "emake failed"
* The die message:
* emake failed
* If you need support, post the topmost build error, and the call stack if relevant.
* A complete build log is located at '/var/tmp/portage/games-emulation/dosbox-0.73/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/games-emulation/dosbox-0.73/temp/environment'
Reply 1 of 2, by Stercus
I am going to upgrade gcc and see if that helps.
Reply 2 of 2, by wd
Rank DOSBox Author
DOSBox Author
gcc version might matter, which one is the above? If upgrading doesn't help
check the configure log for that inline definition as that's where it goes wrong.
