First post, by bushwack
Can somebody point me in the direction of a good midi daughter board or stand alone for the AWE64 in my P200 machine?
Something like this? http://cgi.ebay.com/Yamaha-DB50XG-DB60XG-Soun … =item2c511d113b Little rich for my blood right now, Im outta work. Any cheaper different solutions out there maybe?
Ultimately in a video/cpu guy and sound has always came last, so I don't know a whole lot about it.
Reply 1 of 3, by Old Thrashbarg
The AWE64 doesn't have a wavetable header, so you're going to be limited to either an external box or a separate card.
That daughter card is nice, I've been thinking about getting one myself, but you'd need to find a different sound card to work with it.
Reply 2 of 3, by bushwack
Well i have a Sound Blaster 32 (complete with box and goods 😁 ) I was originally going to use with the system.
So how does the AWE64 midi compare to the add in midi cards people are using? I also have a AWE64 Gold but I think the midi is the same as the Value card I'm using.
Reply 3 of 3, by Anonymous Coward
As far as I know the best you can do in DOS with an AWE64 of any kind is AWE32 mode with the ROM samples. I don't believe there was ever a way to load soundfonts under DOS.
Windows is another story. The AWE64 Gold allows you to load a 4MB soundfont bank in windows, while the AWE64 Value is limited to a 512kb bank. This is of course in their stock configuration. Either card could hold considerably more RAM with the proprietary expansion modules. I find that the midi doesn't really sound like much until you have at least a 4mb bank loaded.
