cd-rom drivers
First post, by Angitherias
How would I go about making my own DOS cd-rom drivers? I know I can get some from bootdisk.com, but one, my laptop doesn't have a floppy drive, and two, the usb port on my old computer doesn't work.. so if I can manually make one (copy)..
Any ideas?
Reply 1 of 6, by swaaye
Rank Moderator
Moderator
you don't have any sort of net access on the notebook? oh pain. maybe time to buy a USB floppy drive (assuming the notebook can boot one).
I don't think there's any way to "copy con" yourself a cdrom driver. 😀 they sorta need to be compiled and stuff.
Reply 2 of 6, by Jorpho
In theory, you could UUencode the driver and then type it out manually on the laptop.
In the unlikely event that there is no UUdecode utility on the laptop already (most decompressors support it), there are also versions of UUdecode that can be typed out manually, perhaps even with "copy con" if you wanted to.
It would be mighty tedious, though, and of course you can't make one mistake.
