First post, by Legend789
Hello 😊 I would like to ask about an error in DragonSphere, and it isn't the speech problem 🤣
My problem is that (Sort of spoilers)
I was playing Desert Sands against the Caliph for the Jar of Flies and the Flagon of Soptus Soporific, but after the game, I had neither in my inventory (and the last item I have, bones is selected). I played for just the Flies and I don't have it either. I remember earlier I went to Slathan ni Patan and I mysteriously had the Flagon before I even really got it. I wonder if that has anything to do with this.
(End of Spoilers)
I would like to know if anyone's had this problem before, and if so, if there's a solution to it. I am currently stuck without these important items 😢
Please and thank you in advanced!
I'm using Dosbox version 0, 72, 0, 0 and my conf file is as follows, if it helps at all:
wrote:[sdl] fullscreen=true fulldouble=false fullfixed=false fullresolution=320x200 output=ddraw hwscale=1.00 autolock=true sensitivit […]
[sdl]
fullscreen=true
fulldouble=false
fullfixed=false
output=ddraw
hwscale=1.00
autolock=true
sensitivity=275
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt[dosbox]
language=
machine=vga
captures=capture
memsize=16[render]
frameskip=0
aspect=false
scaler=normal2x[cpu]
core=normal
cycles=11500
cycleup=500
cycledown=20[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10[midi]
mpu401=true
intelligent=true
device=default
config=[sblaster]
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050[gus]
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=1
dma2=1
ultradir=C:\ULTRASND[speaker]
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true[dos]
xms=true
ems=true[modem]
modem=false
listenport=23
comport=COM2[directserial]
directserial=false
Comport=COM1
realport=1
defaultbps=1200
parity=N
bytesize=8
stopbit=1[ipx]
ipx=false[autoexec]
mount C "C:\MicroProse"
cd C:/Dragon~1
C:
call DRAGON.BAT
exit
