running slow?
First post, by dgw
I've just downloaded and installed Dosbox. However when I start it, it is very slow and basically renders my PC useless as the response times is very long. I'm running XP. Am I doing something wrong?
Thx.
Reply 1 of 5, by Freddo
Possibly.
You won't get a better answer than that without telling us what kind of computer you have or how you configure/run DOSBox.
Reply 2 of 5, by dgw
Thanks for replying. My PC specs are:
CPU: Intel Core 2 Duo E6750 (2.66Ghz)
Mem: 4GB DDR 667
Harddisk: SATA 7200RPM
I have not made any changes to DosBox config, other than install it and started it up. Any help would be appreciated. I want to run Frontier II.
Cheers,
Darren.
Reply 3 of 5, by HunterZ
So your whole system is slow and unresponsive, or just programs running inside of DOSBox?
Also, what is the video hardware in your system?
Reply 4 of 5, by Freddo
dgw wrote:
I have not made any changes to DosBox config, other than install it and started it up. Any help would be appreciated. I want to run Frontier II..
Write this line before you start the game;
CYCLES 20000
Reply 5 of 5, by lightmaster
otoh if you're running fullscreen try another output option like opengl or ddraw
