First post, by kioteh
I've been reading through the DOSBox help and this forum but haven't found a way to use DOSBox to call a 16 bit application from a DOS batch file, have it execute, then close out so the batch file can continue. Can anyone tell me if this is even possible?
Reply 2 of 5, by kioteh
I'm using a call in the batch file to intiate DOSBox, but it only brings up the DOSBox window, it doesn't run my executable.
For example, my batch file looks like this:
call dosbox sa3.exe -noconsole -c "mount s c:\kioteh\"
but when it gets to that part of the batch file, it only opens up the dosbox window, it doesn'execute the command. I can run the commands manually, but that defeats the automation I was hoping for.
Thanks in advance for your help.
Reply 3 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I.e. dosbox -c "mount s c:\kioteh\" -c s: -c sa3.exe -c exit
1+1=10
Reply 4 of 5, by gidierre
kioteh wrote:
call dosbox sa3.exe -noconsole -c "mount s c:\kioteh"
that wouldn't do anyways since dosbox itself is an .exe and no .bat
should you make, say, a run_sa3.bat
whose contents (all paths adjusted!) look somewhat like
then the syntax would be better handled
I mean if you went
call run_sa3
instead, OK?
msdos call (vs. win* only start command) just calls another bat doesn't it
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 5 of 5, by kioteh
Perfect!!! Thanks for all the help. Works like a charm.
