First post, by Gnilearth
DOSBox is a bit new to me, so I wonder why I can use 9 lines in a batch file?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
Please state the problem better.
if you are talking about dosbox -c "switch" -c "switch"
than the answer is because I set that to 10.
but you can easely run a bat file through that
(dosbox -c "call whatever.bat")
Water flows down the stream
Reply 2 of 2, by Gnilearth
Thanks.
I got the answer from the watch windows (console), which says the memory error.
