First post, by ratfink
I have two VESA graphics bards - a Stealth Pro, which gives a normal display, and a Mirage V7. The V7 display looks dim, but also has a yellow cast to it compared to the Stealth Pro [or indeed any other machine I use with my monitor].
I'm assuming the card is failing in some way so it's in the trash, but I thought I would post here to see if there is any other possible explanation. It looks like it's lost one of it's colours.
Reply 1 of 2, by HunterZ
Are you using the same VGA cable and monitor for testing both cards?
Reply 2 of 2, by ratfink
Yes, same cable used each time.
