First post, by 386DX40
Thanks for letting me know how to capture these screenshots Amigaz! I will be adding to this post as I collect these results from several of my old systems for everyone's enjoyment and for comparisons. I will post up the 'best' results from each system.
First system is an original P60 system that I found at a thrift store for 10 bucks. I overclocked it to 66MHz after putting a fan in the front of the desktop style case to blow accross the CPU heatsink. Also spent some time trying some of my various spare parts and memory to achieve these results. Amazingly, the Intel Mercury chipset is able to cache all 128MB of memory as the tag ram is in the chipset itself, and I verified this with CTCM7. I needed two of the 32MB sticks for another system so now it has 96MB in it though. This system is running 98Lite and I have surfed the web with it, but it's slower then my hot rod 486! 😢 It does play Terminal Velocity smoother then the 486 though. That is the only game I have played on it.
Intel Premiere PCI (Batman's Revenge) motherboard
Intel Pentium 60 Socket 4 CPU overclocked to 66MHz
96MB FPM 60ns memory (L2 can cache all of it)
256kb write-back cache
Matrox Mystique 2MB PCI video card
HP 10mb PCI LAN card
Acer Magic S23A Crystal ISA sound card
Via USB 2.0 PCI card
LG 32x IDE CD-ROM drive
Quantum Fireball 10.2GB IDE hard drive witn Ontrack Drive Overlay
Reply 1 of 5, by Amigaz
386DX40 wrote:
Been benchmarking some old rigs (my 386 and 486, plus my new dual Pentium 233MMX box) and would like to post up some speedsys results for your enjoyment, but I can't seem to figure out how to do it. Any suggestions?
Have you put the speedsys software and the PC and it's working?
If it's so when you've done doing a benchmark you get the option to save it as TXT and PCX file...the PCX file is a screenshot 😀
Reply 2 of 5, by 386DX40
OK, have revised the title of this thread, and will be adding to it as time permits. Hope you all enjoy! 😁
Reply 3 of 5, by 386DX40
Next system is a copy of one like it I had back when running a K6-2+ on a regular socket 7 board was a budget way to upgrade....of course the new system has left out the crappy dial up modem! 😁 It is running Win98 SE that has been stripped of some features using 98lite. Using the Opera 10 browser, web surfing is mostly OK, and a tweaked Quake 3 Arena will run 'demo four' at 40FPS. Using the CTU program to enable some K6-2 features helped quite a bit!
Aopen AP5T socket 7 AT motherboard with 430TX chipset
AMD K6-2+ 500 CPU running at 450MHz (75MHz bus x 6)
256MB PC133 SDRAM running at fastest timings BIOS has
512kb motherboard based L3 cache
3dfx Voodoo 3 2000 PCI video card
3com 3C905TX 10/100 PCI LAN card
Sound Blaster AWE64 ISA sound card
Mitsumi 48xIDE CD-ROM drive
IBM 30GB 7200rpm IDE hard drive
Reply 4 of 5, by 386DX40
Next system is based off an old Tyan duallie board that a friend was going to throw in the trash! Since I could never afford anything like this back when it was new, I figured it would be fun to explore it's capabilities. I'm running XP SP3 on this system, and it is actually usable for web surfing and old games like Quake II! I'm wondering how much EDO memory would help over the FPM memory I'm currently using? This particular FPM memory is kinda crappy and I am unable to run it faster then the boards auto 60ns timings without memtest86+ errors.
Tyan 1564D AT dual socket 7 motherboard with 430HX chipset
2 Intel Pentium 233MMX CPUs
256MB 60ns FPM SIMMS (32MB x 8 SIMMS)
512kb motherboard based L2 cache (512MB cacheable area)
Matrox G200 8MB PCI video card
LG 48x IDE CD-ROM drive
Seagate 10GB 7200rpm IDE hard drive
Reply 5 of 5, by 386DX40
Another duallie system, though this one is much more usable even for modern day tasks. Finding compatible ECC registered memory for the motherboard wasn't all that easy though. System runs XP SP3 and surfs the web just fine, and in many ways just browsing and general Windows operations don't feel that much slower then my fastest system which has an E5200 Pentium dual-core running at 3.0GHz. Since Speedsys can't recognize the SATA drive plugged into the PCI SATA card, I have posted my Speedsys result from when I had a 30GB IBM IDE hard drive in the system.
Tyan 1832 ATX dual slot 1 motherboard with 440BX chipset
2 Intel Pentium 3 750MHz CPUs slightly overclocked
1GB PC100 ECC registered SDRAM (256MB x 4)
Nvidia Geforce 4 MX440 AGP video card
Linksys Wireless G PCI LAN card
Sound Blaster Live 5.1 PCI sound card
Adaptec SATA / USB 2.0 PCI combo card
Samsung IDE DVD-ROM drive
WD 160GB 7200rpm SATA hard drive
