First post, by Rottweiler
My old DOS app needs more file handles.
Normally I would put a line like 'files=140' in CONFIG.SYS or CONFIG.NT. Where do I put this in DOSBox?
Thanks.
Reply 1 of 3, by eL_PuSHeR
I think DOSBox uses files=127 internally. To bypass that value you need to recompile the source code yourself.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by Rottweiler
Thanks. I tried my program with files=127 and it worked ok so that evidently isn't the problem. Guess I'll have to try other settings.
