Reply 1 of 5, by Svenne
Is there an option for changing colors in the options menu?
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 2 of 5, by DosFreak
- l33t++
Do you also get a red DOSBox intro screen as well when first starting DOSBox? (in full screen?)
Reply 3 of 5, by GreyGhost
wrote:Is there an option for changing colors in the options menu?
Yes it is. But I would like to understand the essence of the problem. This happens not only in Borland C + +, but in turbo pascal too. All colors in full screen changing to negative.
wrote:Do you also get a red DOSBox intro screen as well when first starting DOSBox? (in full screen?)
Reply 4 of 5, by DosFreak
- l33t++
Try different output= options.
If that doesn't work then you'll need to set the variable, sdl_videodriver=windib.
The next version of DOSBox will have this fixed.
Reply 5 of 5, by GreyGhost
wrote:Try different output= options.
Thank you 😀 overlay output option and all other work good )
