Jo22 wrote:I'm sorry, my posts weren't that helpful. 😢
Cheer up! 😁
I dug out the socket 7 board again, and looked for "PCI (2.0 / 2.1) support" inside the BIOS set up area. Unfortunately that option wasn't there. So I dug out a slot 1 board, an Asus P2B. Its BIOS has a PCI 2.1 Enabled/Disabled option. It also has a PCI latency setting.
Test #1: PCI 2.1 = Enabled, PCI Latency = 32. These are the default settings. Incredibly, the graphics card produced a BIOS POST message. Unfortunately, it quickly went "mad", because the characters on screen became corrupted and garbled.
Tests #2, #3 and #4 were simply combinations of PCI 2.1 = Enabled / Disabled, and also PCI Latency = 32 / 64. For these 3 tests, I got no BIOS POST message. I then tried setting the general BIOS settings to "default" (and not "set up"), and that set the PCI Latency value to 0. Unfortunately, that didn't work either. (I then set the general BIOS settings back to "set up" again, which set the PCI Latency value back to 32.)
Also, returning to test #1 again, I now get no BIOS POST message. Please also note: I have attached a little speaker to the mobo's speaker pins. Now I can listen out for any special error code beeps. For every test, I just hear one "healthy" beep. Also, for every test, the NUM & CAPS keys operate correctly: when they are pressed, the keyboard's lights operate correctly.
The more I think about this, the more I think that the area around the video cable socket could be damaged. The motherboard would not be "clever" enough to realise that this section of the graphics card is somehow damaged, and that is why no special error beep codes are being made.
Unfortunately, the card was shipped to me "loosely" inside a box, and I think it got "bashed about" during transit. I've spent several hours on this video card, and I think I've tried most things. I think you should be able to just stick this card in to an old socket 3 or 7 board without any problem.
Edit: I keep looking at this card, to see if I can spot any signs of physical damage. Looking at the photo in the O.P., you see the 2nd RAM chip from the left. If you look underneath the letters "V3", 2 of the "data lines" are scratched. Also, the solder points immediately to the right of this area have cut marks on them.
