First post, by Asallai
Hi, Im a really big fan of this DosBox and other emulator for Mac osx. Unfortunatelly I had an upgrade for Snow Leopard, but this problem was with the earliest osx version too.
I played with Lands of Lore several time under dosbox 0.72 and that was running well. After the update to 0.73 the game does not loading, nothing happens 😮
After downgrade to 0.72 the game is running perfectly again.
I would like to ask what is the biggest difference between the both version? It is recommend to upgrade or it will be solved later? 😮
Thank you.
Regards,
Andras
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
lands of lore works in 0.73 if you patch the game to the lastest version. (the game has bug that didn't show in 0.72)
Water flows down the stream
