First post, by robertmo
Was Windows 95 C (OSR 2.5) published in an other language than English?
Reply 1 of 2, by Old Thrashbarg
Yes, there are non-English versions floating around out there... I have a Japanese copy of it, myself, but I would assume that it was also published in all the same languages as any other version of Windows.
Reply 2 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yes, Old Thrash is right, I can confirm that Windows 95C was availlable in German as well, even though only as OEM Version, not sold directly in stores, AFAIK.
So I guess all the other languages got the same treatment...
Good way to check is to go to the language specific version of Wikipedia and enter Windows 95. Normally you should be able to make out the version listing 😀
See for example http://de.wikipedia.org/wiki/Windows_95#Versionen
