First post, by DR_MARK
Thank you. I was able to download DOSBox from a different mirror, (San Jose, CA).
But, after I run my DOS graphic program and push Ctrl-F5 to capture the screen, when I dump the image into a Windows graphics program, all the colors are wrong. I tried inverting the colors, but they are still wrong.
Any suggestions?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
dump the image ? it is simply a png that can be opened in a graphics program.
is the screen alright in dosbox itself (so the the windows of dosbox)
Water flows down the stream
Reply 2 of 3, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by DR_MARK
In a DOSBox iI have discovered that it it is possible to capture the image in its correct colors! The image just has to be cropped to eliminate the non-DOSBox background.
So, I'm 😁
