First post, by BlackDragon88
I'm obviously new user of dosbox and I don't understand it at all.. 😁
I have tried to follow these advice:
http://www.commander-keen.com/running-command … -windows-xp.php
"And now you just need to type C:\ and "CD DOSPROG", and you're now in an similar enviroment as MS DOS."
I typed C:\ and it worked. Then I try to type "CD DOSPROG". It says "Unable to change to: dosprog".
Why is it unable to change? What have I done wrong? What can I do to make it right?
