First post, by slrhui
hello!
here is the new version of doboxfro.
for the users who have the old version:
please read the important.txt before install it.
i hope you have fun.
slrhui
    doboxfro.zip
    598.16 KiB
    2676 downloads
Reply 2 of 21, by Predator
slrhui wrote:
hello! […]
hello!
slrhui
what is it ???
Don't be so hard
Reply 6 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
Nicht Sehr Gut wrote:
Does it still screw up subdirectories?
This one never screwed up on subdirectories.
The other one is actually a commodore 64 frontend....
This frontend is this thread doesn't support the loading of zip files so. the subdir issue doesn't apply. Although it would be something to be aware off if a frontend would ever support it.
Reply 7 of 21, by Nicht Sehr Gut
Originally posted by Qbix This one never screwed up on subdirectories.
Ok, I missed the GameBase reference. I was only aware of the existance of doboxfro previously.
How bewildering....no wonder it didn't work properly.
...ungh... I'd rather setup a batch script and have it run by clicking on an icon.
Reply 10 of 21, by Psykotik
Nice shoot. I'm new to dosbox, and it helped me a lot.
But I found a bug, and a thing it lacks :
1.- When you try to load a game from a long folder, containing spaces in the name, it doesn't load at all. You could bypass the issue adding double quote (") at the begining and the ending of each instruction.
2.- Renaming the project's title would be nice !
Oh, I'm almost sure the "dir from dosbox" option doesn't work, but I haven't tested it enough to be certain.
Thanks for your work !
Reply 11 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
slrhui wrote:
to qbix. […]
to qbix.
perhaps I am stupid. but i dont understand, what you
mean with the support for the zip-files.
do you mean the games are zipped??
thanks in advance for your answer.
Somebody (name unimportant) once posted a problem with dosbox. The reason he was having this problem was that he was using a frontend for a C64 emulator as frontend for dosbox. As this C64 wasn't aware af the nature of dosbox it didn't worked allright. Nicht Sehr Gut thought that it as this frontend he was using. (which wasn't the case)
The C64 frontend has support for zipfiles( that was the problem)
The idea is that the frontend unzips the game. starts the emulator with the newly unzipped game as startup thing. This works allright under a C64 but not under dosbox as dosbox creates new files/changes files.
I just said that if a frontend for dosbox (A real one like yours) is ever going to support the zipping and the unzipping of games (and play them) The frontend should be aware of the fact that dosbox creates/modifies files/directories.
Water flows down the stream
Reply 13 of 21, by maYO
Perhaps I am just too stupid,
but how can I configure dosboxfro to automount a directory on dosbox startup.
The automount function hasn't been implemented yet,
but I guess an entry in the AUTOEXEC should do it.
But it doesn't work. 😕 😕 😕
DOSBoxGui - multi platform DOSBox frontend
check my weblog (german only)
