First post, by Nicht Sehr Gut
- l33t
An old PC:
Yes, sometimes, this is simply the best possible answer. Sometimes all the hacks, patches, and tricks combined simply aren't enough to get older titles running. Sometimes you just have to give it the hardware for which it was originally designed.
"Old PC's" should be relatively cheap and easy to find. Just remember that in addition to running "old" titles, they also bring back "classic" problems that some modern PC users may have forgotten about: slow speed, smaller hard-drive storage, fewer BIOS options, greater likelihood of hardware/software conflicts, finding older hardware to work with your older PC, etc...
Upsides: Greatest chance of success of all the options. Game programs and setup programs are more likely to behave as they should. Downsides: Takes up more space. Useful only for "old" programs (most people will find them too slow for general operation). Even with a slower PC...your program may run too fast (or too slow!). Eventually, it will break down and die, forcing you to move to other (more recent) hardware.
This, by the way, is the primary reason for VOGONS existence. At some point, "using old hardware" simply won't be a viable option. By that time, we will need emulation or some other fix for the problem. Finding these solutions will be very difficult when running the original program (the way it was designed to run) is no longer possible.
