First post, by keldorn
Hi guys,
I've been browsing through these forums for a few days now, trying to get Theme Hospital to work.
I eventually remembered how to mount drives in dos etc, and set my dos games folder to c:\users\myname\oldgames
I then installed the game to that dir.
I then tried running the game with the following comand:
c:\users\myname\oldgames\cd hospital (hospital being the file name on installation)
c:\HOsPITAL\hospital.exe
SUCCESS!!! It works! ....uhhhh problem, the screen size is too small, i want fullscreen! So I edit the config and set it to fullscreen.
Now, I go through the same process...YES it's fullscreen!!!....but wait?
"Theme Hospital requires the cdrom to play"
And that my friends, is where I am! I have tried obtaining a No CD crack, and have applied the crack successfully through dos, but still the issue persists. I always mounted the cdrom to:
mount e e:\ -t cdrom
but I don't get anywhere.
Please guys, any help would really be appreciated! I really miss this game, and I will be the first to admit I'm no pro when it comes to DOS (and PC's in general!!!)
Thanks loads in advance!
Reply 1 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
start anew.
Read 60 seconds guide to getting your game to run in DOSBox and don't just read it, follow it.
Your problems come from mounting different stuff, installing not from within Dosbox and so on... If you follow the guide it should work fine.
Next time, please post in the Dosbox forum, not the Dos one.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 7, by keldorn
Sorry for posting in wrong forum, just saw the "getting old games to run" description and thought this was the best place, will create threads in the dosbox one in future (mods feel free to move this to there)
I am following the guide to the "t" but I have become stuck. It tells me to:
Z:\>mount D "D:\" -t cdrom
MSCDEX installed.
Drive D is mounted as CDRom D:\
If your "DOSBox stuff\MyGame" folder is located on say your real F-drive, then do a mount C "F:\DOSBox stuff\MyGame".
If your real CD-ROM drive is E:, then do a mount D "E:\ -t cdrom".
Now my games file is located on C, so that works fine, but my cdrom/dvd is E, so when I add the line:
I get the message, "directory e:\ -t cdrom" doesn't exist
Any advice?
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
ah a small mistake in the guide
Thank you for following it that close
mount D "E:\" -t cdrom
I corrected the guide
Water flows down the stream
Reply 7 of 7, by keldorn
ah a small mistake in the guide Thank you for following it that close […]
Code:
Thanks, I noticed it too after a while and a cup of coffee 😜
Thanks loads for the guide again! Really helpful and I get to play this classic!
Cool community spirit too 😎
