First post, by keropi
- l33t++
Hiya!!!
Yesterday I installed my original copy of TV (big boxed too!) on my p200mmx machine... The cd installed the latest 1.2 version, all went well , I setup my sound and run tv.exe ... but NO. It just quits after the message:
Loading sound driver...
So I quickly moved my HDD to a pII/233 machine, booted DOS - same crash. One final test revealed that a K6-II/450 can run it (no surprise there - it is known that K6's are more tolerant to speed issues)
The first thing that came to mind was that tv.exe was a TurboPascal exe. Tried patching it, even unpacking it in case it was compressed with an exe compressor. No luck there too , looking inside the file I can clearly see "watcom C" message and it is not packed at all. Something must exist I am sure, the time TV was out was close to cpu's at 200+ mhz.... Any info would be appreciated!
ps. I found a way to load the game without tv.exe , just load the corresponding .com for your soundcard and then start game.exe . I don't know if this is a safe way to run it though...
