First post, by 1130210
I have a problem with DOSBox games. Its more a question and not so much a "I simply cannot play any DOSBox games they are virtually unplayable" Anyway, my question is Why do some DOSBox games run slow and other do not? Hopefully, someone can give me an answer and a solution to this problem. Let me explain...
Some games that I have problems with are, just randomly, Wing Commander and The Elder Scrolls II Daggerfall. Wing commander and Daggerfall both work at a fairly good speed. But, both of them slow down at certain moments throughout the entire game. These moments make the games unplayable at certain parts in the game. The slow down is incredibly annoying because the noticeable change in fps is infuriating and makes the games unplayable. In Daggerfall it slows down inside the houses (not the outside or the dungeons) in Wing Commander it slows down when ever I face a ship. These things are obviously annoying because they make questing and exploring towns annoying, in daggerfall, and with wing commander it destroys the combat.
I wonder am I just being picky with the slowdown, does this happen with anyone else, and is there anyway to fix this? As I said, this happens with so many games and besides my system specs are more then suitable for the games
Nvidia 8600 GT
AMD Athlon 64 X2 Dual Core Processor 4000+ 2.10 GHz
Vista
2814 MB of ram
60 GB of hard disc space
I always see on different forums people talking about DOS games running slow for them. But the answer is always get more ram or get a 1.5 GHz processor. But I have well enough system requirements.
Anyway, please help me try to fix this problem.
Reply 1 of 11, by wd
Rank DOSBox Author
DOSBox Author
Some games deploy techniques that hurt performance of the cpu emulation,
in some cases this affects the overall speed in some it is only intermittent.
First try to rule out some parts of the emulation causing this, like turn off sound
in the game. Then try various settings for the cycles= parameter in the dosbox
config file (there's a full section about performance in the README btw.)
Reply 2 of 11, by DosFreak
Not all DOS games are equal. The games you mentioned were very demanding back when they came out, even on the fastest processors today games run in DOSBox can run only approaching a level of a Pentium 166+. (but not in all cases and that's with the fastest processors).
Your processor is far from the fastest.
Also verify that no spyware/malware or other processor intensive tasks are running on your system while using DOSBox.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 11, by 1130210
I realize my processor isn't the fastest. But another person mentioned in another forum that my computer should be able to play all these games with a smooth fps. That's why I came here, I want to know if there is something wrong with my computer or with DOSBox. I'll try checking for spyware and tinkering around with DOSBox.
Reply 4 of 11, by DosFreak
One person's "smooth" is another person's "unplayable". Be sure you both are talking about the same areas being played.
Also most of the advice you hear on the internet about DOSBox is from people who don't know what they are talking about. If it's not advice from here that don't take it as gospel.
Reply 8 of 11, by ratix
why not set your cpu to max in the dosbox config file IF you are already using a fixed cycle rate. mainly cuz in the game doom the more stuff you have going on screen the more it taxes the cycles thus causing it to slow down in frame rate. at least i think im right with where im goin with it.
the only heavy graphics game i played through dosbox was staytooned through windows 3.1 and phantasmagoria and both had moments of slowdown only when being read from cd.
Reply 9 of 11, by wd
Rank DOSBox Author
DOSBox Author
Neither does this sentence make sense nor would, reading it either way, this be a good suggestion.
Reply 10 of 11, by Serious Callers Only
Does profiling aided compilation help at all on these cases?
I'm wondering also if it would be possible or even desirable to emulate at the dynarec level some techniques of modern cpu's (out of order execution for example)
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
Only if e.g. graphics output (scaler etc.) are source of the problem.
This indeed may work, given that the recompiled blocks live very long (this is
not true for several heavy-games though). Can't think of any reordering/pipelining
or whatever that may help though.
