Cannot Install SimTower
First post, by malekyte
I have attempted to try and install/play SimTower through DOS Box. Here are my stats, errors and other bits of info. YES I have read the README, 60 second Guide, and Installation Tips and Hints.
DOS Box v. 0.73
Windows 7 x64 Professional
Gigabyte MAS motherboard
Athlon X2 Processor
*Drive G is an external HDD
*Drive X is a virtual CD-Rom via Power ISO w/ SimTower mounted on it (did attempt to do this without a virtual drive to the same error)
*SimTower was downloaded from [DON'T DO THAT]
Command List
1. mount C "G:\DOS Box"
2. mount D "X:\" -t cdrom
3. D:
4. dir /w
5. setup.exe
6. simtower.exe
You can see the error in the screenshot "This program requires Microsoft Windows", and when I enter in command #6 it just freezes as you see in the screenshot. Any help would be nice, thank you.
    332.75 KiB
    366 downloads
