s3 gamma correction
First post, by ratfink
In windows 95 is there a way to adjust the gamma when running games in a dos box? Using an s3 trio but I can't find any settings to change.
Reply 1 of 2, by DosFreak
IIRC, there were some S3 drivers that came with a interface to adjust properties but even if you could find that I don't think DOSBox has support for that implemented.
If you can't find it then you'll probably have to use a 3rd party tool.
The above mentioned is for DOSBox the emulator not the Command Prompt aka "dos box" in Windows.
Make your games work offline
Reply 2 of 2, by robertmo
I don't think he is using DOSBox in win95 😀
you can try PowerStrip
or better monitor
