First post, by swaaye
A little guide on how to get it Carmageddon to work with Voodoo 3/4/5.
Example system
  • Abit BF6 440BX
  • Pentium III 600
  • 256MB
  • 80GB HDD
  • Voodoo5 5500 AGP
  • SB16
  • CDROM
  • Win98SE "DOS 7"
config.sys (essentially as below)
himem.sys  (or himemx)
dos=high
dos cdrom driver
autoexec.bat
SET SSTH3_SLI_AA_CONFIGURATION=4   (4X FSAA on Voodoo5)
mscdex.exe
mouse driver
The Windows 98 video drivers appear to initialize the card. So you can boot into Windows and play the game, or boot into Windows and then reboot to pure DOS and play. It runs smoother in pure DOS.
I did a full install of the game. With the Max/Splat Pack, the 3dfx.exe that is included works with the Voodoo5 (add the option -vrush to stop HUD flicker). Another exe that works is the Voodoo2 patch from http://www.patches-scrolls.de/ (voodo2c.exe) and this runs without the CD if you did a maximum install.
Voodoo5 FSAA
OS: all
HW: VSA100-based cards
Desc: SLI/AA setup
Note: (*) (!) works only at Glide-level?
Value:
1, 2, 4 chip cards
"0" - SLI & AA disable
"1" - SLI disabled, 2 sample AA enabled
2, 4 chip cards
"2" - 2-way SLI enabled, AA disabled
"3" - 2-way SLI enabled, 2 sample AA enabled
"4" - SLI disabled, 4 sample AA enabled
4 chip cards
"5" - 4-way SLI enabled, AA disabled
"6" - 4-way SLI enabled, 2 sample AA enabled
"7" - 2-way SLI enabled, 4 sample AA enabled
"8" - SLI disabled, 8 sample AA enabled
Reply 1 of 2, by possossod
Hello, I would like to thank you for the info you've posted above.
I've spent quite a few time trying to fix the flickering hud issue since I thought it was driver related, but it was simply a wrong identification path by the game fixed by a simple executable option.
Btw here's my Voodoo5 system:
  • Intel Pentium III 1.4GHz Tualatin
  • Abit ST6 with 815EP chipset
  • 2*256MB Crucial 133MHz CAS2 SDRAM
  • 3Dfx Voodoo5 5500 AGP with upgraded copper cooling and VRAM heatsinks
  • 64GB Zheino PATA SSD
  • Creative Audigy
  • Intel PRO/100 S NIC
  • Plextor Premium CD Burner
  • Lian-Li PC-61 case
  • Enermax EG365AX-VA 365W PSU
  • Windows 98SE with all available updates
The system is really fast and what was the week spot of the systems of that time was loading times it's gone with the usage of the ssd.
Reply 2 of 2, by genghiskhanpl
Hi, I was able to play carmageddon 1 on my voodoo3 but no luck. The voodoo2c patch runs the game without acceleration, and other exe files from the splat pack cd scream for the disc even though it is in the drive. Has anyone managed to run this game on v3?
