First post, by mmmax99
I received this from my brother but I cant get it to install on my desktop. I downloaded D-Fend reloaded but I cant figure out how to if possible install or run the game from the disk. Im no dosbox expert by any means and barely computer literate. Im dying to play Bards tale 1 2 and 3 but my computer apparently is not. I have an old Dell Dimension 4500 desktop thats running windows Xp. ANy help would be appreciated.
Reply 2 of 12, by mmmax99
This operation is not supported in secure mode.
Cant mount any drives.
Reply 4 of 12, by mmmax99
Well I figured out what that problem was but am still having trouble with this install. think I really screwed the pooch up. If I assigned the wrong drives to dosbox will it always recognize them when I run it or can I just rerun and try again. Wasnt recognizing C drive either.
Reply 5 of 12, by wd
Rank DOSBox Author
DOSBox Author
Strange. But user error.
Reply 6 of 12, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 12, by mmmax99
I think the problem may be in the fact that the cd has many games on it. The only executable file I could run was one called DOSSETUP. Which I ofcourse did. Which brought me to a screen, asked which game i wanted installed, I picked and then poof nothing. I see under the my cdrom dir that there are subfolders. Is there a way I can access them in DOS and try run and exe from the subfolder?
Reply 8 of 12, by robertmo
get dosbox from www.dosbox.com (and don't use d-fend or any other)
Reply 9 of 12, by mmmax99
Thats what I did. I uninstalled the d-fend and went to dosbox.com directly.
Reply 11 of 12, by mmmax99
Got it from a different site. Disk is more problem then its worth. Thanks all for your help.
Reply 12 of 12, by robertmo
i don't know what you mean but i think by following the guide i posted above you should be able to run these games easily.
