First post, by laangelsrule
I am running DOSbox on a dell with XP and when i try to run x-wing, the program shuts down. Anyone able to get x-wing to work with DOSbox?
Reply 1 of 11, by robertmo
have you configured game's sound properly?
Reply 2 of 11, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 11, by lightmaster
have you installed the game within dosbox of your original disc(s) ?
Reply 4 of 11, by Mr_486
eL_PuSHeR:
Do you not get tired of moving every single post in this forum to the DOSBox forum?
As I said in another thread can someone not rearrange the index page slightly so people find the right forum first time?
Reply 5 of 11, by laangelsrule
I turned the sound off, also tried several other options. I am using two different downloads of the game - they work with an online version of DOSbox (version .72) and it works with that but many times I am not online and unable to access the game otherwise.
Thanks for the help!
Reply 6 of 11, by leileilol
I can confirm this: It doesn't freeze/shutdown for a legal disk version copy.
DOSBox doesn't rely on the internet. There is no online version.
long live PCem
Reply 7 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
in fact where do find an online version of DOSBox ?
it might be a virus or so
Water flows down the stream
Reply 8 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Wasn't there a custom build of DOSBox that was tied into Valve's Steam client for some of their DOS game packages?
Reply 9 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
only for a very brief period of time.
they replaced with a normal build later
(and it was a normal build to begin with, it was just a "wrapper" around the dosbox executable.)
Reply 10 of 11, by laangelsrule
huh, very interesting. . . thanks for the heads up, guess i'll go back up my computer now just in case. if anything bad happens, i'll be sure to post where i downloaded the stuff from
Reply 11 of 11, by Malignant Manor
Do not post where you illegally downloaded the game.
