First post, by Waussie
Hello everyone,
I just tried a few frontends, and was thinking of creating my own.
I just wonder how some features are to be configured in dosbox.
If anyone could help me out here, cause i couldn't find it in the wiki or docs,
but seem to be implementable because some frontends do configure them.
- Run a dosgame and after it closes, close dosbox aswell.
- Can i configure the -noconsoleflag by default,
for instance place it in the .conf or something?
I thank you for all your help.
Waussie
Reply 1 of 8, by gidierre
make a batch file, with the -noconsole and -exit commands.
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 2 of 8, by Waussie
I use the folowing string in my program:
dosbox.exe -noconsole "%1"
Where %1 is the dosgame executable to run and is variable.
So where do I put the exit statement or that batchfile?
A batchfile like this:
exit
Doesn't seem to work!
Also I can't put the exitstatement in the autoexec section of the conf, because dosbox will than close before the game is started.
Reply 5 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
readme.txt or just readme that comes with Dosbox
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 8, by dma1968
I have a problem with -exit.
My batch file is:
dosbox.exe c:\laf1\run.bat -c -exit
run.bat is a file for launch aplicatioon.
I test other options but never run.
The aplication run correct but not exit from DOSBox when program stops.
Thankyou.
dma1968
