73 Config?
First post, by ray5450
Why does version .73 not come with the configuration file (dosbox.conf)?
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
it does ?
but at a different place with a different name
check the console windows of dosbox (and check the start menu!)
Water flows down the stream
Reply 2 of 5, by ray5450
Ahh. It's in C:\Users\"user"\AppData\Local\DOSBox
By the way, since I did not know that, I had put the old file back in the dosbox folder in Program Files. With both available, it uses the one I put in Program Files\Dosbox instead.
Thank-you.
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Bad idea because they are incompatible so problems are up to you.
Reply 4 of 5, by ray5450
First, I only did it because I didn't know where the new one was until now. I have no issue in using the new one.
Second, I compared each line by line and found only 2 minor differences in the sound settings.
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
why not stick to the shortcuts we provided
and there are more differences between 0.72 and 0.73 aside from the sound settings.
(machine for example)
