First post, by thomas001
Hi, i looked a bit into the opengl output of dosbox and made some changes i'd like to post for discussion.
  • remove GFX_RGBONLY check from gl output, as opengl can do RGB in 32bit. advantage is opengl output together with scalers like hq3x.
  • move texture coordinates half an pixel into the image. this should prevent interpolation with not filled areas in the texture for the right and down edge of the screen (i get strange gray lines at those edges otherwise). top and left edge where moved in because for symmetry.
  • remove NV_pixel_data_range support and add ARB_pixel_buffer_object support instead.
  • fix opengl extension recognition. simply using strstr() is the wrong way.
Everything works fine on my system, but the patch has not been tested on other systems.
comments are welcome 😀
    dosbox-0.7.3-glstuff.diff
    8.92 KiB
    160 downloads
    the patch
Reply 1 of 4, by robertmo
if you check CGA Compatibility Tester, version 0.5a from http://www.oldskool.org/pc/cgacomp
with:
machine=cga
windowresolution=1280x800
output=openglnb
scaler=none
you will notice that the main menu screen, and moire tests don't look properly.
Reply 2 of 4, by thomas001
robertmo wrote:
if you check CGA Compatibility Tester, version 0.5a from http://www.oldskool.org/pc/cgacomp […]
with:
machine=cga
output=openglnb
scaler=none
Thanks for your testing. i changed the patch. now when bilinear filtering is disabled texture coordinates are set as before the patch. also the patch now checks for ARB_texture_non_power_of_two. this is a opengl 2.0 core feature (we detect it anyway for <2.0 implementations) that allows textures of arbitrary size. so the texture doesn't need to be bigger than the actual frame is.
    9.86 KiB
    120 downloads
    new patch
Reply 3 of 4, by gulikoza
During my tests I found that non-pow2 textures are much slower than pow2. Maybe this is already fixed in the last generations of the cards, but since dosbox does not really use that much texture ram slightly bigger texture is not an issue.
Also I'm not really sure about the texture coordinate offset. Direct3D does have a 0.0 coordinate in the center of the pixel, but OpenGL IIRC has 0.0 coordinate in the upper left corner.
http://www.si-gamer.net/gulikoza
Reply 4 of 4, by thomas001
oh sorry. i did not know there where slower...
i did not introduce NPOT textures because of the small memory benefit. i searched for a way to get filtering right. the thing is that linear filtering at the right and bottom edge of the screen will be wrong, as it filters with the "width+1"-th and "height+1"-th pixel. with NPOT textures the texture is exactly width x height so the screen edges are actual texture edges and the problem does not occur. those offsets are another approach which work, but they cut of half the area of the border pixels, so not an ideal solution either. perhaps this is unnoticeable when bilienar filtering is turned on. the last idea whould be to manually copy the last column and row, which whould result in correctly filtered borders but sounds slow...
... i whould remove the NPOT texture code again and use the offsets iff bilinear filtering is enabled?
edit: we could also add additional textured quads on the right and bottom edge which "fake" correct border interpolation. those quads whould be half an dosbox pixel width.
