First post, by retro games 100
- l33t
I'm testing this FIC socket 7 mobo:
http://stason.org/TULARC/pc/motherboards/F/FI … um-PT-2011.html
If I set the BIOS set up External Cache option to "write back", then after the BIOS POST DRAM memory count has finished, an error message appears on the screen saying "Cache memory error". The BIOS set up area screen then automatically appears. And so I must change this External Cache option from "write back" to Disabled. Then, after the BIOS POST DRAM memory count has finished, I get no "Cache memory error" on the screen, and I can then proceed to boot in to Windows 98.
The mobo is able to accept both 72-pin EDO RAM, and also SDRAM. I am using just 1 stick of SDRAM, 64MB. Is the external cache really faulty, or is there something I can do to avoid seeing this cache memory error? Thanks a lot for any ideas.
