First post, by bagheera
Hi, i'm using DOSBox 0.73 and DBOXfe 0.1.3 frontend. I want to play old polish dos game "ElectroBody", everything is working fine EXCEPT gamepad.
It's 10 button Logitech Precision model. It is detected by dosbox:
dosbox cmd output -> Using joystick Logitech Logitech(R) Precision(TM) Gamepad with 2 axes, 10 buttons and 0 hat(s)
but it's not calibrated. By default pointer goes to top-left corner, and no other buttons works (like 'fire')
I have checked some options, and best what i've got is with following config:
[joystick]
joysticktype=2axis
timed=false
autofire=false
swap34=true
buttonwrap=true
Now pointer stays in the middle (ingame character is not moving), but i can only move him left and jump, so only left and up buttons on d-pad work. Still no "fire".
There is no "Mapping.txt" file around.
Is any fix for that?
I'm using Arch Linux.
Here's entire config from frontend:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority="higher,normal"
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=vga
memsize=16
captures=capture
[render]
frameskip=0
scaler=normal2x
aspect=false
[cpu]
core=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplrate=22050
oplmode=auto
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\\ULTRASND
Show last 32 lines
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
joysticktype=2axis
timed=false
autofire=false
swap34=true
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
ipx=false
[autoexec]
Btw, is wiki page working? I only get total blank page in Opera :s
Linux user
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
nope wiki is broken since yesterday. Not sure what is entirely wrong yet
Water flows down the stream
Reply 2 of 4, by robertmo
remove that frontend it is too old
install dosbox again and try again
Reply 3 of 4, by bagheera
Update:
Fire is working, i just forgot there is no ammo at beginning 😁
Solved!
I've been using buggy dev version of game, 🤣. I found newer version and gamepad is working flawlessly.
Sorry for such an silly issue. *(and my english)
Linux user
Reply 4 of 4, by HunterZ
Thanks for the update, it may help others who have the same problem in the future.
