Sopwith?
First post, by JoelAs
I need to get my Sopwith fix..
I recall with older windows (Win95-98) there was a version you could play that had some minor tweaks for CPU speed.
But now, with Windows7 everywhere, good luck! I can't find the old versions and the new versions are junk too?
Searching the forums it sounds like DosBox is the solution, just some issue with passing the -S command line option? I will try anything to flatten some cows so I'll go try that.. 😉
Back when I was a boy, we carved our own IC's out of wood.
Reply 1 of 1, by leileilol
SDL Sopwith covers the Linux base. Dunno about a Win32 port of that.
long live PCem
