I just retested my CT3980, and it's completely silent now. Before, I was able to get effects working but no music. Now, I can't get any sound from the card. I replaced it with a CT3990, and used the same HDD with the same PnP settings, and that card works OK, so I think the first card, the 3980, is broken in some way.
Also, I bought some 30-pin SIMMs, which were advertised as 8MB each. I was quite excited by this, because it would be nice to have an AWE32 with 16MB of RAM on board. Unfortunately, the seller seems to be confused, because they only register as 2MB (for a pair of sticks) using diagnose.exe. Visually, they also look like 1MB sticks.
Question: I believe it's possible to have as much as 28MB onboard an AWE32. I guess this means 2 sticks of 16MB (32MB), and the 4MB left over (32-28=4) is not available to the card. But as 30-pin SIMMs are quite rare these, especially 16MB sticks, is it possible to get a 30-pin to 72-pin memory stick "converter"? It's easy to get hold of a couple of sticks of 72-pin RAM. If I could slot these 72-pin sticks in to a converter, then attach the converter to the AWE32's SIMM slot(s), that would allow me to get the maximum amount of RAM onboard the AWE32.
Any ideas please people?
