First post, by Martyn
I'm new on the board so some of my questions may be a little redundant:
I have an Older 16 bit dos application (Multi User) that works fine in the dos box "even Multi users and or multi dos boxes up at the same time" So all is good there.. However I'm running into problems sharing printers or for that matter gaining access to printers.. In XP 32-bit we simply used the NET USE
command.. however that is not available in the dos box.. any ides would be appreciated.. BTW I'm running this on Win7 64-bit Ultimate..
