First post, by yawnmoth
I'm using Duke Nukem 3D v1.4 - Atomic Edition and I can't, using the attached savegame, play for much more than a minute without DOSBox crashing. When this happens the status window fills up with lines like these:
Illegal write to 10003de, CS:IP       70:     e62
Illegal write to 10003df, CS:IP 70: e62
Illegal write to 10003e0, CS:IP 70: e62
Illegal write to 10003e1, CS:IP 70: e62
Illegal write to 10003e2, CS:IP 70: e62
Illegal write to 10003e3, CS:IP 70: e62
Illegal write to 10003e4, CS:IP 70: e62
Illegal write to 10003e5, CS:IP 70: e62
Illegal write to 10003e6, CS:IP 70: e62
Illegal write to 10003e7, CS:IP 70: e62
It actually says that that so many times that the following can't be seen in the status window at all:
DOSBox version 0.73
Copyright 2002-2009 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\Users\wiggie\AppData\Local\D
OSBox\dosbox-0.73.conf
MIDI:Opened device:win32
Scrolling to the top doesn't help - the Illegal error just continues up to 10002bd. It may go farther than that but the status window doesn't show that many lines even with the scroll bar.
    savegame.zip
    245.96 KiB
    318 downloads
http://www.frostjedi.com/terra/scripts/graemlin.php
Reply 1 of 7, by DosFreak
Somone mentioned last week that Blood would crash at a certain point unless they increased the memory that DOSBox is assigned.
By default DOSBox uses 16mb so try bumping it to 32mb.
Make your games work offline
Reply 3 of 7, by filipetolhuizen
Atomic Edition is memory hungry, increase it to the maximum possible if you want a smooth gameplay. Also try patching it to 1.5 if you have a chance.
Reply 4 of 7, by yawnmoth
The fact that the same thing just now happened makes me think that you're right - that I just need to upgrade.
Illegal write to 20003e0, CS:IP       70:     e62
Illegal write to 20003e1, CS:IP 70: e62
Illegal write to 20003e2, CS:IP 70: e62
Illegal write to 20003e3, CS:IP 70: e62
Illegal write to 20003e4, CS:IP 70: e62
Illegal write to 20003e5, CS:IP 70: e62
Illegal write to 20003e6, CS:IP 70: e62
Illegal write to 20003e7, CS:IP 70: e62
