Hercules orange color
First post, by colguetti
Hi, sorry to bother you all but I can´t find the way to select the hercules color 😁 , I know I know, it´s monochrome but I used to play some games on an orange monochrome monitor and I just wanted to play them as I´m used to, also I remember having a WANG with a 9" green monochrome display....
Please feel free to move this post if you feel it goes into another forum
Thanks in advance !!!
Sorry for my english, I speak spanish and my english is self-taught 😖
Reply 1 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Because you created this thread in the development section, here is a way to have what you want by changing the source code in int10_modes.cpp:
    case MCH_HERC:
IO_WriteB(0x3b8,0x28); // TEXT mode and blinking characters
+ VGA_DAC_SetEntry( 0,0x02,0x01,0);
+ VGA_DAC_SetEntry( 7,0x37,0x28,0);
+ VGA_DAC_SetEntry(15,0x3f,0x34,0);
VGA_DAC_CombineColor(0,0);
VGA_DAC_CombineColor(1,7);
real_writeb(BIOSMEM_SEG,BIOSMEM_CURRENT_MSR,0x29); // attribute controls blinking
break;
It's a hard-coded color scheme; making it configurable is more involved. Note that the hercules emulation only uses palette entries 0, 7, and 15; and the RGB values range from 0 to 0x3f. You can create just about any color scheme you like, but I guess amber or green would be the most nostalgic variants. I used a close-up image of an amber monochrome monitor from Google images to come up with the colors in the example; and I set the background color to have a hint of amber just to add to the simulation.
Text with different attributes:
Game graphics:
Reply 7 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Here is a patch against current source that has a somewhat better chance of being committed than the hack I first wrote about. Similar to how the CGA machine type allows composite color hue to be changed with F11, I've used the same key to allow cycling among white, amber, and green monochrome colors on-the-fly. It starts out in white for backward compatibility.
Welcome screen showing added message about F11 in green color:
    hercules_palette.diff
    2.26 KiB
    401 downloads
Reply 11 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It retains the palette when changing from text to graphics, but not when switching to a text mode. New patch for that "little" issue.
    hercules_palette_2.diff
    2.82 KiB
    335 downloads
Reply 14 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
h-a-l-9000 wrote:
Nice idea. One thing to point out: The difference of intensity seems a bit more visible on real hardware (at least on my weird green multiscan monitor)
suggestions for better values ?
Water flows down the stream
Reply 15 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I made the green values by simply stripping the red and blue from white. 😅
As I understand it, human perception of brightness/intensity is most sensitive for green, less for red, and much less for blue. There are several functions for computing equivalent perceived brightness as colors are changed. In this case it may just come down to preference.
Reply 16 of 25, by HunterZ
Nice, I had to use an amber Hercules setup for a couple years around 1990 when the EGA monitor in my 8MHz 286 blew out from overheating due to someone putting a printer on top of its vents 😳 Does SIMCGA work in DOSBox while running in Hercules mode?
Reply 17 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
hal could you try some values out ? It is only value that needs possibly to be changed.
You got the real thing afterall.
Reply 18 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
	case 2:	// Green
VGA_DAC_SetEntry(0x7,0x00,0x26,0x00);
VGA_DAC_SetEntry(0xf,0x00,0x3f,0x00);
But yes it's highly subjective.
For some reason Eclipse didn't want to apply the patch.
1+1=10
Reply 19 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
0x26 instead of 0x2a ?
Fine by me.
the patch applies fine at my place. I'll look after it.
