First post, by cmulligan01
I have some experience with DOXBox had I had it working on my barely year old Asus laptop with Vista. I'm using DOSBox 0.73. I just downloaded D-Fend Reloaded. I don't know how to use the two together. However since upgrading to Windows 7 I can't get any of the games I'm trying to install to install after copying the game to a folder on my HDD. I have Windows 7 Home Premium 64 bit. Maybe I'm missing something obvious but I can't figure it out. I've read this board, googled trying to play X-wing, TIE Fighter and Dark Forces.
Honestly what I need is for someone to hold my hand to get 1 game installed.
Reply 2 of 3, by DosFreak
Perform an install through DOSBox first, once you understand what is going on then then try an install using the frontend.
The frontend performs the same commands but it hides them from you. If you have no understanding of DOS but are trying to do "DOS" things the frontend can complicate matters.
Make your games work offline
