First post, by robert2040
A number of years ago I wrote a program in Visual Basic 6 to act as a front end to an old 16-bit QBasic program. After setting up a bunch of variables, the Visual Basic 6 code launches the 16-bit program as a separate process and waits for its completion.
On Windows 7, 64-bit mode, the 16-bit program will not run. The Visual Basic 6 front end, however, still works fine.
Here is my question: Is it possible for my Visual Basic 6 program to launch DosBox (instead of my 16-bit program) and then have DosBox launch the 16-bit program? Perhaps by my using the DosBox autoexec feature. Or perhaps there’s a DosBox API available for this sort of thing.
Any information you can pass my way would be much appreciated.
Thank you.
Robert
Reply 1 of 12, by ADDiCT
There's no API, but you can pass parameters via the "autoexec" section in dosbox.conf, or create a batch that you call via "autoexec" and which then runs in DOSBox.
Reply 2 of 12, by robert2040
Thanks for the reply.
I was testing DosBox last night. Do you know whether DosBox can be launched completely invisibly? I know I can use the "-noconsole" option to hide that screen. But how about the main DosBox screen? Can that too be hidden easily?
Thanks.
Robert
Reply 3 of 12, by IIGS_User
I don't think it's possible to hide the main DOSBox screen because you need a reply about what happens within DOSBox.
Remember, DosGamesOnlyBox.
Klimawandel.
Reply 8 of 12, by robert2040
Let me be more specific in my question. You said I should set the following:
set sdl_videodriver=dummy
Do I set this in the DosBox configuration file or is this a Windows environment variable? Specificially, where do I set this?
Thank you.
Reply 9 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
windows, but why not try both yourself to see which one worked instead of posting here a few times.
This option would have given you the answer much faster.
Water flows down the stream
Reply 10 of 12, by robert2040
I'm a software developer. Of course I tried both before posting here. I also tried various launch methods within my code. None of them allowed me to launch DosBox fully hidden.
However, because of your last specific post, I realized that I had been using upper case for the environment variable. Usually in Windows, case doesn't matter. Anyway, I just tried it using lower case and it works now.
Thanks for your help.
Reply 11 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
ah yes, I had to repair dosbox in the past as well as we upcased the value by default as well when updating the emulated environment. was one game that wanted a lowcase value
Reply 12 of 12, by cobol30
I am currently working on a dos game menu system, that runs with ScummVM, DosBox and DosBox using Windows 3.11. I am writing it in Visual Studio 2011, below is the method I use to start DosBox. This code starts DosBox without the console been shown, it also hides the form when DosBox is started, and reshows the form when DosBox terminates. I hope this helps.
Public Declare Function apiFindWindow Lib "user32" Alias "FindWindowA" (ByVal strClass As String, ByVal lpWindow As String) As Long
Public Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Public Function IsProcessRunning(ByVal ProcessName As String) As Boolean
Dim WMIServicesObject As Object, WMIServicesItems As Object
IsProcessRunning = False
WMIServicesObject = GetObject("winmgmts:\\.\root\cimv2")
WMIServicesItems = WMIServicesObject.InstancesOf("Win32_Process")
For Each WMIServicesProcess As Object In WMIServicesItems
If (Trim(LCase(WMIServicesProcess.Caption)) = Trim(LCase(ProcessName))) Then IsProcessRunning = True
Next WMIServicesProcess
WMIServicesObject = Nothing
WMIServicesItems = Nothing
End Function
Public Sub StartGame()
Dim DosBoxParameters as string = "-noconsole -conf game.conf"
Dim DosboxExecutable as string = "c:\program files (x86)\dosbox\dosbox.exe"
Me.hide()
ShellExecute(apiFindWindow("OPUSAPP", "0"), "open", DosBoxExecutable, DosBoxParameters, Mid(DosBoxExecutable, 1, InStrRev(DosBoxExecutable, "\")), 0)
Do
Loop Until (IsProcessRunning(Mid(DosBoxExecutable, InStrRev(DosBoxExecutable, "\") + 1)) = False)
Me.Show()
End Sub
